OMC 3.0 Spring recomissioning ???
G. Arruda
Looking for some words of wisdom on recomissioning my boat after a long winter. <br />This is my 1 st spring with my boat. It got put to bed last fall with w/ a full winterizing... oil"s" changed, fogged, drained.<br />Now to get her goin? My 1st ? is the drain cocks, should I use any anti-sieze or sealant on the threads ? also, should the block be flushed from the water pump inlet, or just hook the muffs up? Did a tune-up middle of last season, anything need to be addressed there? <br />Any other tips would be great!<br />Thanks lots, Gary
Laddies
Banned
Re: OMC 3.0 Spring recomissioning ???
Anytime a unit set a couple of monthss it's a good idea to ck gear lube, anti seize is a matter of preferance, just don't over tighted the drain plugs or you will hate yourself in the fall. Then hook up the muffs and light the fire
G. Arruda
sounds good , thanks!
