OMC 3.0l 1988 failed ESA
chopperdog
Engine stalled and won't start.
If I connect the battery directly to the coil, it runs like a champ.
I can't get any voltage out of Shift Module (part number 987740) to coil, in any condition.
Interuptor switch and over shift switch(sp?) both tested correctly.
Should I order a new Shift Module?
I have points, not electronic ignition.
Thanks,
chopperdog
Anchor Management 1
Re: OMC 3.0l 1988 failed ESA
Since you have points don't run it long with 12 volts you will burn up the points.
