I have a 1992 OMC 3.0L that is difficult to shift into neutral. I have to wiggle the throttle to get it to go into neutral. I was reading that it could be the ESA module. I wanted to get some thoughts on this. Where can I find the ESA module and test it out. Also where can I find a replacement and what is the relative cost of the ESA. This may be unrelated but when I shift into gear, it shifts hard. It grinds into gear as if you were shifting your car into gear with having the clutch all the way down. Could this be related? Any help is appreciated.
