Serf27
- Joined
- Aug 23, 2018
- 167
Hey all.
I’ve asked for help here with great success from most of you, but I can’t catch a break on this 4yr project.
3.8l OMC V6 2barrel carb.
Old fuel completely drained
New main fuel line from tank to pump. New fuel water separator and new fuel filter.
First, the cranking issue:
The old fuel had some water mixed into it and so did the fuel water separator.
I cleared all that out and the engine cranks (most of the time) in short bursts.
Like it cranks over half a spin and then half a spin and then cranks normally until it starts. I thought a valve/piston bent due to water in the fuel, but cyl compression yielded 150 psi across all 6.
It sounds like there is some resistance and it can’t fully crank. With the spark plugs removed during compression testing, it was spinning over fine.
What would cause this? I will get a video of it doing it, it does it 75% of the time.
Almost like there is too much compression…?
I will pull the accessory belts off too because I’ve had that issue on some cars.
The battery is brand new.
And I used 87 octane fuel.
I hope the explanation of the issue makes sense.
Dying issue:
It can probably idle until it runs out of fuel and can coast at 2K rpm.
Last week I was getting up to 4k rpm and it would die after about 30 seconds. It always started back up.
Today I was at about 3500 rpm for 30 minutes and it was fine. Later in the day, it would start to sputter and die and wouldn’t want to start, not until I cranked it over a few cycles. (Cranked 1, 2 and 3 separate times)
Sucked fuel out of the main fuel line, took about 2 seconds to get fuel out and the fuel water separator had fuel in it too. I opened the fuel fill cap and then it started and I just coasted back to the dock at 1500 rpm.
But because the engine doesn’t want to turn over as freely, it takes a toll on the battery I believe because it needs extra power to turn the engine.
Could the cranking issue be a bad ground?
And the dying issue?
I’ve read to look for leaks in the fuel hose, clogged tank vent, fuel pressure after the pump.
I have not touched the carb, that is the next item to do, but if there is something I’ve missed, please let me know.
I do know the fuel fill cap is attached to the tank via a 1.5” or so hose, and the clamps on that hose are not tight, but would that just act as a vent as well? Since the main fuel line is clamped tight to the tank and the pump?
Thanks.
Dying issue:
Thanks.
