I own a 1989 Omc cobra 4.3.I have been experiencing a bad stumble or missfire only when trimming the drive up,and only at high rpm's(3000,or better).I replaced the points,plugs coil,cap, rotor,and wires,which improved over all, but did not solve the stumble when activating trim switch.I manually depressed the esa switch and it did interupt the spark,so i'm assuming its fine.I read that omc issued a service bulletin regarding this problem and it spoke of cutting the resistor wire down 22 inches.Can anyone confirm this?Also there were a couple of members who experienced this same problem,but no posts as to what finally cured this annoyance.Is trim wire chaffing in the throttle box a common problem with these omc's.the problem started out as a slight stumble, and has progressivley gotten worse.thanks for any help.
