Usually 'checking' the points/cond,cap,rotor plugs doesn't tell you much. replace these items, check/change fuel filters, water seperator, anti siphon......a full tune up. After setting timing and adjusting carb, post back with results. If you did a search, there is a multitude of different failures that cause this issue. You have to be absolutley sure the basics are in order and then can go on doing compression tests, fuel tests, coil and other things.
