I have a 1987 4.3L Cobra (GM engine) which started overheating weeks ago on the lake. I'm pretty anal about watching my gauges, and noticed withing 2 minutes of launching, that the temp was about 200 degrees and climbing.
We beached the boat, let it sit for about 2 hours, and started it again. It had cooled off (so the temp. sending unit doesn't seem to be the problem), then it heated right back up to 200 or so.
Trailered it, and put it on the muffs at home, and it does the same thing every time. By process of elimination, I've replaced the thermostat, checked the impeller (new at the end of last season), and replaced the engine ciculation pump.
I've drained the block, and it is scalding hot water, but is clean and clear. The temperature on the exhaust manifolds seems to be uniform and luke warm.
The only oddity, I'm not sure if I just never noticed it before, is that most of the water is now coming out just after the transom, near the exhaust releif valve, very little coming out through the prop.
I'm at a complete loss. I've been told that it may be the exhaust manifolds, but is it typical for them just to go all at once like that? I've never had a problem until the last time to the lake, and now it won't do anything but overheat. I would think if the manifold was going out it would start running hotter, or be an intermittent problem.
Any ideas??
Any ideas??
