Omc 4.3l Problem...please Help
fourwinns88
The boat in question here is an 88' Four Winns 200 Horizon w/ 4.3L and an OMC Cobra outdrive. In detail, here is my problem: The boat will run in neutral just fine until I plugup the shift assist module and it dies completely. I have not tried shifting into gear without this part working correctly. With the module plugged up I check the voltage at the coil and zero. Unplug the module and now voltage at the coil. I have adjusted the shift interrupt switch per the manual and it checked out fine. I am baffled and don't know what to do next. Can anyone help?
