OMC 5.0 Cobra Ignition -1992 Four Winns
Grundei
I have had a nagging ignition problem - When under full power if you hit the trim button (up or down -makes no difference) you get a pop - similar to a small backfire and a slight reduction in rpm. Previously it would not accelerate without touching trim button - I found that by flexing the plug on the wiring harness I could make the problem occur - after attempting to clean the plug - clamp tighter etc - I removed both plugs and hard wired each of the individual wires. The major problem went away - now left with the "pop" when touching trim under full power. Any ideas on where to go next? A mechanic mentioned a "Control Module" but it was a guess.
Thanks!!
