peanutbay1
- Joined
- Jun 4, 2009
- 91
Hello;
This is my first posting but I have read the forum for quite a while and found much good information. My "88" boat has an OMC 5ltr engine. The problem is that the boat has developed an intermitant surge at 4100rpms,almost like if a plug was firing sometimes and not others. If you dump the throttle it will sputter out the carb and if you roll on steady she will pull strong up to 4100rpm and then after that slowly fall on her face or try to surge into full rpms (4600). Here is what I have done so far:
1) plugs,wires,cap,rotor,new petronix electronic ignition,coil.
2) rebuilt the rodchester 4bbl carb
3) new water/fuel filter,carb fuel filter and checked my pick up line.
The bottom line is I bought the boat last year and got the outdrive section dialed in but did not work much on the engine side but It had this surge condition then. With all this work I still have the same condition but the boat does pull much stronger than last year. A few questions;
1) Could this be a timing problem?
2) Any other paths to go down?
PLEASE HELP!!!!!:
PLEASE HELP!!!!!:
