Ok guys so this is my first year winterizing this boat, done it with plenty of outboards and Merc IO’s but my first OMC I/O, Have an 1989 OMC Cobra 5.0HO *ford engine* After reading all the info on this site I think I’ve got it down. I know everyone says read this and read that, but I feel a good engine specific how to is really lacking, unless I’ve totally missed it.
If I haven’t missed anything then I’m going to take photos of each step when I actually accept that winter is coming and decide to winterize. I’ll post it on here as a great how to for people.
The following is my plan, if this is incorrect let me know, if wrong and it screws up your boat, i'm not responsible!
1. Put in fuel stabilizer, fill up fuel tank, and Change fuel/water separator filter
2. Startup boat on muffs and let run until normal operating temperature (15-20 min)
3. Change oil and oil filter (use SAE 30 Oil per engine recc.)
4. Restart engine, let run for a few check for oil leaks and levels
5. Fog the engine: Remove flame arrestor, fast idle engine and spray fogging solution until stalls. (some people then remove spark plugs and spray oil in there also)
6. Drain the Engine:
a. Remove Drain plugs from port and starboard side cylinder block, use wire to ensure holes not clogged
b. Remove Hose from manifolds let drain
c. Remove raw water intake hose and drain
d. Remove water circulating pump hose and drain
e. Drain Power steering oil cooler
f. Close drain plugs
g. Reattach hoses expect if filling with antifreeze (debated topic on here as well), if so fill with antifreeze in the circ pump until it comes out the top of engine, also put antifreeze in manifolds and power steering cooler. Then reattach hoses, if you filled with antifreeze some people say to crank the engine a few times to make sure it got everywhere.
Engine should be good to go for the winter, now onto the stern drive
7. With unit trimmed down remove the bottom drain screw and then the top dipstick. Check for shavings and milky oil. If you have this then it’s time to remove the drive and fix it over the winter.
8. Filling a cobra seems to be a topic as well. I’m going to stick with the manual on this one. Once drained replace the lower drain screw. Then remove the middle fill screw. Use 64oz of high visc. Drive oil. Replace dipstick, let set and check at a later time. Deff check after the winter before taking it out and check after the first time taking it out. (Unless you want to replace your upper gears for being lazy)
9. Now trim the drive up and remove the water drain plugs (one port, two starboard)- DO NOT REMOVE THE DUMMY SCREW
10. Trim down; crank a few times to ensure water pump is out of water along with passages. Then trim back up to allow any extra water to drain, trim back down, then replace drain plugs for the winter if you’re leaving the drive on, some people like to remove the drive and store elsewhere…
11. Lube gimbal, universal joints and pretty much anything else that needs grease
12. Remove batteries ensure they are charged and store. I’m storing mine in the basement to avoid the chance of freezing. Just not on concrete as I've heard that is bad for batteries for some reason?
13. You’re done, now just dream of warm days.
So that’s it and my plan, did I miss anything or should I be good… If so as I said I’m going to photograph each step and repost on here to help people out.
