omc 5.7 fuel pump
jmacgowan
I have a 92 chris craft concept 223, 5.7 omc. I need to replace the fuel pump. The fuel pump that is on the engine doesnt match either option that is called for in the parts book, I have found a visual match in the book which is a pump for a V6 4.3 does anyone know if that could be a pressure or volume issue
Re: omc 5.7 fuel pump
Ayuh,... They're all 5psi pumps,+ I believe the volume won't matter...
The motor uses no where near what they can pump...
