OMC 800 lower unit shifting
SeaSkwurrel
'81 OMC 800<br />I've been having hard shifting problems so I pulled the lower cable housing to check the cables. When disconnected from the lower unit, pulling the wires is a little difficult. Does that indicate a problem? Also, should I be able to easily push and pull the splined bar now exposed on the lower unit while turning the propeller shaft to put it into gear? I want to make sure I don't have some other problem in the lower unit.<br /><br />Thanks!
SeaSkwurrel
Re: OMC 800 lower unit shifting
Additional info-this unit has the hydraulic power assist servo.
