A month ago after replacing the top gear set I put the 26' Sunrunner Chev 305, OMC Stringer 800 back in the water. Leaving the dock the first time it popped out of forward on hard acceleration ONE time, then all was well. This was with a 15-1/2x13 prop. Two days ago after seeing WOT RPM at 3,800 I tried the only other prop I had on the boat, a 15-1/2x19 which I thought would totally bog my boat down. But the top rev is now 4,150 or so, but it wants to pop out of forward both on the way up to plane and once at plane. Any ideas what I might be missing here? Is the 19 prop pitch putting too much torque on the gears...is the lower unit oil I used (90 weight) not perfect enough for the gears down there...I have separate shift from throttle control cables at the helm. Is there some spring detent ball that's supposed to keep the throttle in forward better? To run for 10 minutes at plane I held the shift lever with light pressure and it didn't jump out of gear.
HELP if anyone can. There are so many sharp people at this site, it's truly fantastic. Jay in Seattle
