Hey guys,
My Omc 800/350 will not go into reverse. On land with muffs it seems to work but I have to have the cable way extended. The pointer on the shift converter has to go way off the scale like an inch to even get the reverse to work on land. When I put it in the water it seemed like it was spinning somewhat at idle but when revved it was slipping. Forward seems to work in the range that it should but now there is huge separation between the two. When I adjusted the cable to get reverse to slip in the water, forward also slipped so I had to readjust back towards forward more so that would engage fully again. The cable going down to the outdrive appears tight with no slack around the bellcrank. Any ideas?
Thanks
Thanks
