I have received alot of great advice and help on here. I need just a bit more from the OMC experts out there.
I am installing a new clutch dog and reverse gear on my 800 outdrive. I am having trouble getting the prop shaft with the clutch dog installed. On the end of the clutch dog rod which sticks out of the end of the prop shaft is a shift cradle which meets with the shift lever. This is what moves the clutch dog when the shift rod is moved.
How do I get the cradle to connect to the lever. I am trying to slide the prop shaft down the lower unit housing and into the oil pump where the cradle and lever meet up. It seems almost impossable to me to make these two pieces fit together. Is there a trick to this? Do I need to remove the oilpum and fit these pieces together somehow that way? If so how do I get the oil pump out.
Any help would be appreciated.
Thanks
Thanks
