Re: OMC 800 Outdrive Questions
The motor oil is for the tilt mechanism clutch pack. You have four areas for fluid lube. The afore mentioned, the intermediate housing, the upper and lower gearcases The later three all take 75w-90 MARINE gear oil. Depending on the year, you may not have a drain plug for the intermediate housing. Just make sure it is always full. It takes very little lube as it only lubricates the tapered roller for the ballgear to flywheel shaft. <br /><br />There are also four zerk fittings. Two behind the rubber bumper caps for the outdrive pivots and two for the lateral steering shaft. One of those is accessed under the outdrive , on the intermediate housing, by the steering gear. The other is inside the transom, on the intermediate housing by where the steering shaft enters the forward shaft support bushing.<br /><br />Also, if you have tru course steering, you'll want to get a lubricant inside the cable housing to keep from getting increased steering effort.
