GiMLit
- Joined
- Jul 27, 2007
- 194
I picked up my parts donor boat this weekend.
81 18 ft Tempest 3.8l OMC 800 Sterndrive. Model # 982566
This afternoon I stripped it out pretty much except for power plant and drive.
I have a manual for the electric shift drives but not for the cable shift units.
Since the cost of the cables seems to be very high and I would rather not learn by trial and error, can anyone give me needed pointers for sterndrive removal relating to cable removal?
Is it pretty much the same as the electric shifts electric harness removal?
Actual unbolting is no bigdeal but cable routing, unclipping, etc.... is the details I would like to have.
Also one other issue I had was removal of the steering assembly. It has the OMC "Power Pointer" steering on it. It would appear that I need to knock the shaft out towards the drum unit after removal of the wheel, roll pin and pointer gear assembly. Again this looks straight forward but doesn't seem to want to come apart. Hidden clips, pins, tight splines? Picture shows how far I have it.
Thanks in advance
Thanks in advance
