I recently inherited a 1978 Glastron from my grandfather with the OMC 800 on the rear. Everything was working great until one day the tilt would not come up. Luckily I could trim the motor and raise it about 2 inches off the ground, and since I live 1/2 mile from the ramp, was able to get her home without dragging the ground.
I did some reading, and evidently this is a common problem. I decided to start working on the issue last night, and thought I would check/clean the clutch pack out. I opened it up and sure enough, it looked like spoiled chocolate milk. I pulled the clutch packs out, cleaned them up, soaked them in WD40, greased everything and reinstalled. I also read where you can remove the three bolts holding the tilt shaft cover plate so that the lower unit can be moved more easily. So, I pull the cover plate off, and noticed a cap and could not figure out how to remove it. So, I just let it be. However, it did seem like it was a little crooked in the shaft, so I'm not sure if I have a problem there as well.
Anyway, I reassemble the clutches and button everything back up. Now, I can easily move the lower unit by hand, but the tilt function does not work. I am wanting to take the boat to the lake this weekend, and am worried when I put it in reverse that it will cause the lower unit to kick up and possibly break a u-joint or worse.
The only thing I can think is that I possible assembled the clutch pack incorrectly. In looking through the manual, it says there are three washer looking pieces call springs. I am thinking I maybe put them in backwards. From what I remember they had a slight dome shape to them, but I am not 100%.
So, now for the question. Should I be able to easily move the lower unit by hand like that or is something put together wrong?
Thanks for all the help!
Chris
Chris
