Had a bad shift cable, replaced it. Checked cable from console to engine, OK. Did center out-of-gear procedure on shift converter box, OK. Put muffs on, ran engine, shifted gears perfectly. Put prop in water, won't shift, chatters, will not go into gear. I'm guessing stripped gears or something else in the lower unit? The loading on the prop is causing something to change.
