omc adhesive sealant
wade1961
I can not find the omc adhesive can I use permatex type adhesive ? I am installing a water pump on a 1981 115<br /><br /> Thank you<br /> wade1961 :confused
Joe Reeves
Re: omc adhesive sealant
Wade..... The following may be of interest to you.<br /><br />Sealer 1000 or OMC Adhesive (same substance) should be used on any metal to metal or metal to plastic surface (such as impeller hsg to plate) to eliminate air leaks. It should also be used on the Spaghetti tubing that is used on many powerhead crankcase halves, lower unit skegs, etc. I have found that this substance works quite well on various "O" Rings such as what are found on lower unit carrier and upper driveshaft bearing housings (Note that this substance is obviously not to be used on all "O" Rings).<br /> <br />DO NOT use any sealer on the large "O" Rings that are used on the upper and lower crankcase heads (The housing/heads that slide over the top and bottom of the crankshaft). On those "O" Rings, use only a coating of grease.<br /> <br />Sealer 1000 may also be found in other brand names such as "Boat Armor" but the name of Sealer 1000 will always be mentioned on the tube.
wade1961
Thanks Joe I will see if I can find Boat armor sealer 1000<br /><br /> Later<br /> Wade1961 :cool:
Joe Reeves
Wade.... I neglected to mention that the original Sealer 1000 is manufactured by Marprox and is listed as "Marprox Sealer 1000".
