omc binicale instructions
jimp1221
I hooked up a omc binicale to a 2000 johnson 50 hp and everything works but i can't get any rpms above idle in reverse i bought it from ebay with no instructions
bob johnson
Re: omc binicale instructions
were the cables on your boat already???
or did they come with the control???
have you carefully watched the action and movement of the cables at the motor while someone else manuvers the control???
that would go a long way to figureing out whats going on...
what control do you have?...got a picture?
I have two , one on the boat and a spare....both have been on my boat working, so if mine is like yours , i might be able to help walk you through...
bob
jimp1221
I will get you a picture. and yes someone watched it at the motor i moved it into reverse and it does actualy the thottle cable seems to be extended but i have no rise in rpm thouggh if i press down the nutral buttom on the top i can get the rpm up
jimp1221
the cables came with it and i was told they would wor on my boat
bob johnson
the throttle on the motor is the same for reverse and forward!!!!!!!!!
if the throttle on the motor is moving after your motor goes into reverse...the control is not the culprit
you need to watch that the motor shifts into reverse in the first part of the throw of the control and there after the throttle starts to move...
the movement either forward or backwards on the control should be about the same, each way, before the throttle cable starts to move...
have you tried the boat in the water under power yet???
bob
jimp1221
yes i have in foward i have good throttle but in reverse it just idles it seem though when it goes into rev gear i have no more movment to the to raise the rpms
jimp1221
i had it out under way several times
