scout-j-m
- Joined
- Jul 31, 2009
- 642
I recently purchased a 1992 Johnson 15hp. It came with an OMC 8" aluminum prop. Maybe saying it is a BRP prop is a better description as it is identical to the current style of Johnson/Evinrude props they sell here on iboats and I have no clue if thats what the OEM ones looked like back in 1992.
Anyways, the motor is on a 1648 Alumacraft flatbottom (~300 lb hull, 35 hp max rated) with 6 gallon fuel tank, group 29 battery, trolling motor, floor, fishing gear, and two 170 lb men. I'd consider it a relatively light load for the hull. With the weight distributed just right and the motor trimmed so that the anit-vent plate was parallel to the hull bottom it ran at WOT at 6800 rpms and 19 mph. According to a prop calculator that is only about 11% prop slip which I would imagine is excellent for a riveted flatbottom hull with such a small motor as compared to the hull rating.
The motor has a WOT range of 5500-7000 rpms I believe so the 8" prop seems like it will be a good one to hang on to and pair with my load. But I haven't ran the motor with me alone in the boat so I would like to get a second prop in maybe a 10" pitch for those situations. Possibly even a 9" 4 blade as it may be a good compromise for running with either 1 or 2 people and not having to change props.
I still have an old 3 blade, AL, 10" pitch prop from my 1982 9.9hp Evinrude I need to try before I make any decision, but my point of all of this and my question is to see if anyone knows the difference between the current Johnson/Evinrude/BRP props being sold compared to the after market brands like Solas, Turning Point, Michigan Wheel, etc in terms of cupping and blade size particularly for these smaller props for these little 9.9/15hp motors like I have?
