I'm in the process of reconnecting all of the wiring harnesses (engines pulled to rebuild trans/stringers). I have OMC 350/5.7 Cobra's. There are two 50amp fuses that mount near the harness on top of the engine. Each of them have a wire coming off of them with an eye-connector. I assume these would go to the startes, but I took one engine out, and simply done remember there being two connectors from these fuses to the starter. Do they both go to the same connector on the starter? I only have one open terminal on the starter. My manual does not specifically show where those connect.
Thanks!
Thanks!
