OMC Cobra 5.0 EFI
mjb94
I have a 334 Chris Craft that has two I/O OMC Cobra EFI engines. I had them professionally winterized. I was putting it all back together last weekend, I found where all the disconnected hoses and what not go but then I got to these Bolt looking things that have a hole in them, there were 3 I believe. Its fairly short, with a hole in the side where there are threads, this hole goes all the way through. and connects to the one in the top. They were down in the engine pit with all the other things removed, I appreciate anyhelp to what these could be, they may not be to the engine but if anyone knows that would be helpful to me. Thanks,
Mike
Don S
Re: OMC Cobra 5.0 EFI
Sounds like you are describing the petcocks used as block drains. Look on the left and right sides of the block for a brass fitting that those plugs for the petcocks fit into. They will be located just above the oil pan, and in the water jacket of the block.
Just curious why no one wants to give the year of anything. Do you all think every year is the same? Nothing ever changes?
mjb94
Ok Ill check there this weekend,
I dont know the year, im looking this up for my dad because ho couldn't find anything on it, im 14, and now i at least have a place to start.
Thanks
