skidooseadoo83
- Joined
- Apr 5, 2012
- 32
I posted in another thread and was advised to start a new one... Im seeing this repeated over and over again in lots of threads. I havent read anything put out specifically by OMC saying this is how it is suppose to or not suppose to work.
Ill start with my disclaimer... im not a "marine" mechanic... where can I find an OMC description of the ESA shift logic... I have seen a couple threads with people saying two completely different things and now im starting to wonder... ESA activates when shifting in and out of gear, and on this thread, only out of gear. To be honest, it makes perfectly good mechanical sense that with a dog clutch set up it would activate both ways. (a dog clutch is not a friction clutch, it simply pushes two gears, one containing engine torque continuously rotating, and the other containing the "load", stationary until engaged, together. "perfectly good mechanical sense" would be that two gears being meshed together as described will have more stress placed on them the higher the rpm they mesh at) I have an 89 capri, 2.3l cobra i/o, updated lower cable, shifts with ease, all my cable dimensions and shift measurements are within spec, no problems at all... and my ESA activates going in and out of gear. It was actually out of adjustment hard shifting when i bought it, clunked really bad going into gear, stiff shifter, no ESA stumble going into gear. After adjusting everything to spec, shifts like a dream. I know i have read literature related to the ESA stating the new 5 deg gear set was less inclined to disengage (not written by OMC, actually by Stuart) and they came up with an updated ESA that reduced RPM further to facilitate ?make disengagement easier,? this makes perfect sense... but no mention of this is made by OMC in any bulletin or manual I have read, they simply state "hard shifting,"... any thoughts? If it really isnt suppose to activate when shifting into gear i need to find whats wrong.
