Andy Spidal
- Joined
- Jul 27, 2018
- 6
1993 seaswirl new long block. Ford 302 model 502APRJVB, serial number TO 1250965. I have been using it for several seasons once or twice a year so not a lot of hours on new engine. It shifts into gear fine but to get it in neutral I pull throttle back all the way pause then pull back several more times and hopefully it hits neutral. There is only 1 switch on the shift bracket and it has continuity at the plug when closed. When engine is running and switch is activated no stuttering of engine. ESA module engine side of plug all pins show ground. I can’t find a replacement ESA module to shotgun it as a possibility. All post I read talked about testing switch and nothing else. Any thoughts? Do any of the pins connect to power? I have a ESA from a V6 but I assume it is different? I can operate the boat but it makes me nervous if my kids drive I would like to fix it.
