omc cobra help!!!
snoorton
my 4 winns with 3.0 cobra, overheated today on lake mead,<br /> <br />I had the impeller replaced monday,<br /> the boat shop said they had back flushed it,.<br />this time, the alternator belt broke, and overheated..<br /> The Pulley that turns the belts ,both impeller and alternator,can be turned by hand either direction,but, <br /> THE engine will not turn this PULLEY<br /> 1995 fourwinns I/O<br /><br /> I need help advice .<br />this pulley is somehow connected to the crankshaft??? could this connection be the problem?<br /> I am not a mechanic, and am very short on funds.<br />also, I have noticed a small leak from the exhaust water hose, this may not be real important at this time,
tylerin
Re: omc cobra help!!!
The pulley on the crankshaft is what turns the altenator pulley and waterpump pulley. The crankshaft pulley won't spin free, it will start turning once the engine is running. Replace the belt(or have it replaced). The "small leak from the exhaust water hose" should be addressed immediatly. The waterpump in your motor compartment is not the impeller, the impeller is located in the sterndrive. The waterpump is a circulating pump.
Lou C
I think if it is a 95 it has the impeller on the engine, not back in the upper unit like the earlier Cobras. You might want to have the mech replace the belts and run it on a water hose to make sure it gets enough circulating water and then try it in the water.
tylerin
My Cobra manual goes from 86-95. I could be wrong
Lou C
Whey OMC redesigned it for 94, it was made under the joint venture arrangement with Volvo Penta so the OMC Cobra got basically the same system as the Volvo SX Cobra (shifting in the upper unit, engine mounted impeller). Probably less trouble overall that the older 86-93 ones, and all the parts are shared with the Volvo,so you can get it serviced in a Volvo shop.
