Hello, I am having problems getting my OMC engine to start. I have a 1987 OMC Cobra - GM 350 V8 with a Mallory single point distributor. This engine is mated to the corresponding Cobra outdrive - complete with E.S.A. circuitry. The main problem started showing itself on my last outing, when it would run well for a while and then die for no reason. After another full day of running without problem, I figured it was a fuel clog or something. The boat was put away for the season after this trip and now will not start at all. It will not even show a spark coming off the high tension wire from the ign. coil. I have rebuilt the distributor with points, rotor, condenser, cap, etc. I replaced the ign. coil with the same model coil, as well as the ignition key switch. I have pulled off all ignition wire connections (that I could find)and cleaned any corrosion (which was very little). The boat only sat a couple of months w/ stabilizer in fuel. I have taken the voltage reading tests as outlined in the owner's manual, and everything so far checks out (voltage to coil '+' side, voltage to points - with motor cranking & with ignition just in "on" position. The starter motor cranks, gauges work, trim/tilt works, basically everything except for my secondardy ignition voltage. My last thoughts are that I have a bad ground at the distributor casing to the engine block. I am thinking about running a new ground wire from the block to one of the side bolts on the distributor. Any responses or suggestions would be greatly appreciated. I would love to be able to handle this problem myself and not have to tow it to a shop - just yet. Thanks!
