Ok Guys, Last year I put the boat away with a impeller problem. I think I have a blockage. I burned a impeller last so I replaced it and took the boat out and burned another. The thing is that when I took the impeller out it had fins that were facing the wrong way. I know I put it in with them all in the right direction. I did run it on muffs at home and it worked fine. I checked it out after I ran it to see if there were any fins pointing in the wrong direction. There were none. Then I took the boat out and ran it at a good speed for about 20 mins and started to over heat. Whan I took it apart some fins on the impellar were in the wrong direction. Would a blockage couse pressure to build and move the fins or is it some thing eles. What common places may block up in a 88 4.3 omc cobra. Or is this not even a blockage problem?
Any help is appreciated, Ray
