Re: OMC Cobra leaking milky gear oil from water inlets (new thread)
A year ago, I had a local shop replace the bellows and do a pressure/vaccum check on the drive. I also has the manifolds and risers replaced at this time. I'm wondering if maybe this is something I can have them fix...I guess if the check was good at that time, none of the seals would have been replaced, therefore nothing would be covered by them.
As far as the water pump, i know it has a standard one on the front of the engine, where should I look for the one you're asking about?
Thanks,
Harley
