Good evening, hopefully some of y’all knowledgeable in boats could point me in the right direction. I really don’t know much about boats but I’ll do my best to explain. I have a 1992 Four Winns Horizon 190, OMC 5.0 with Cobra outdrive. Just want to go ahead and throw it out there that my max speed was always about 30 to 35 on this boat (not sure of RPM) but the prop was a 14x21. One day I slowed down fast to avoid a shallow spot and water came through the Y pipe and hydrolocked the engine. I was able to unseize the engine, in the course of spinning it through 8-10 sec at a time to spray out the moisture from plug holes, I melted the impeller housing and didn’t realize it until I took it out on the water and it started overheating on me. It would start to accelerate and then it would feel like it was straining very very hard and then it would just lock up. I replaced the impeller and the housing and verified water going through the thermostat. I let it idle for about 40 minutes in my driveway with no problem in the engine temperature never went over 160. My problem now is, even though the boat will idle forever with no issues, if I slightly rev it on neutral it will lock up in about 2 to 3 seconds and make a shudder which seems to be more noticeable on the outdrive but I’m not sure. My personal thought is that the old exhaust shutters weather melted or deteriorated are clogging something in the engine is back pressuring when I put accelerate. Because it does the exact same thing whether in neutral or reverse or forward. I took off my lower unit today but I did not see anything stuck and also the white pipe seems to be clear of any debris. If anyone has any advice or suggestions I would greatly appreciate it.
PS: The water spout inside the lower unit seems to have melted plastic around it I do not know if this is something that needs to be replaced or not.
