I've been working on 1988 5.7L OMC with OMC Cobra outdrive. The outdrive cable is new, but, someone else installed it. After several attempts to adjust Forward/Reserve, according to the strict guidance of the original maintenance manual, here are my challenges:
1. Can push/pull the tranmission linkage by hand(remote cables off), but it takes a significant force(approx 40lbs) to move it into Reverse. Forward has a similar resistance. The resistance is more at the Neutral end of the shift throw than when closer to F or R.
2. When remote control cables are attached, cannot engage Reverse fully from my flybridge controls or my cabin controls. At engine, by hand, I can move it the last 1/8" to 1/4" into reverse.
3. No, the Electronic Shift Assistance is not an issue.
Photo shows reverse fully enaged position of shift cable housing.
Have followed following instructions via manual and following:
http://www.hastings.org/~stuart/cobra/
Have read several iboats and other forum threads that are related, including...
http://forums.iboats.com/showthread.php?t=331906&highlight=OMC+outdrive+cable
http://forums.iboats.com/showthread.php?t=330845&highlight=OMC+outdrive+cable
Technicians familiar with OMC outdrives are not easily found here in Ensenada, 2 hours south of San Diego.
1. Any/all suggestions, gotchas, experiences welcome.
2. Anyone with OMC 5.7L and OMC Cobra outdrive in SD or Orange County who would be willing to let us see correct setup/operation would score beverage of their choice for the live show at your marina/dock/garage.
THANKS
THANKS
