Recently purchased a 89' 5.7 cobra outdrive to be used as a stand by.The unit was on a running boat. After close inspection outdrive fluid was found leaking from the large seal behind the joint shaft assembly. If I bring the shaft assembly to a repair shop for seal replacement what would a ballpark cost be to replace this seal. I would supply the seal. The part number from doug russell schematic was # 29. Thanks in advance.
