Hi guys...ran across this site while searching for a fix to my problem. Hopefully you can help me on this one.
Ok, so last fall I purchased a 1989 Lund Tyee with a 4cyl omc engine and a cobra outdrive. The engine model is 302APRMED, and the stern drive is a model 985684.
When I put it in the water for the first time last fall, to do some fishing, the boat started fine, but once I put it in forward, it would not come out. this caused me to ding my prop a bit. I continued fishing anyway....with no neutral or reverse.
once done fishing, I loaded it up and brought it home to see what the problem was. all it was, was the shift cable came out of it's little "notch" because the cotter pin was missing. So I just put it back in place.
Fast forward to this spring.....put the boat back in the water and all seemed fine, except that it shifted hard. Forward was stiff, and reverse was even stiffer. then the other day, no reverse at all. I removed the shift cable from the bracket on the engine and tried pulling/pushing on it to see if it would shift. with the engine running (on trailer with garden hose hooked up), I could pull on the cable and it would shift into forward with no problem, then I could push on it and get neutral. however, it would not push in anymore to get reverse. when the cable it attached to the shift mechanism, it will go into forward, and neutral, but when I try to put it in reverse, I can see that it puts pressure on the shift cable, but the cable will not move. It just won't go in reverse. no grinding,,,,no nothing...just stays in neutral.
now my question....could this be an adjustment, a bad shift cable, or is my reverse gear toast? I had no problem with reverse gear before this, except that it would shift hard. no ratcheting or anything like that....just hard to shift, but did go into reverse.
I just ordered an OMC repair manual for for it, as well as a parts list catalog, but would like to get a jump start on the problem with a little help from you guys, if possible. My other boat had a stringer 400, and I learned my way around that drive, including rebuilding it twice myself over a 15 yr period. I am just not familiar at all with the cobra. and from what I have read, the cobra outdrive is notorious for eating up gears....is this true?
any suggestions or thoughts as to what could be wrong?
Thanks.
Thanks.
