OMC Cobra Shift Adjustment
rybad
Does anyone have any good info on adjusting the shift cables on '89 OMC Cobra drive (5.7 litre engine).<br /><br />I have an '89 Four Winns 285 Vista, and the shifting gets very difficut at time. Sometimes it seems OK, but other times I have to practically put half my weight on the levers or jam them swiftly to get them to shift.<br /><br />I'm not sure if its a cable problem, or just and adjustment. The guy I bought this boat off of a couple of years ago, said that he had the "modification" from Four Winns installed several years ago (as this was a known problem that was fixed by OMC).<br /><br />Any thought, suggestions, tips ??<br /><br />Thanks.<br /><br />-David
Boatin Bob
Re: OMC Cobra Shift Adjustment
The modification may have been the "NEW RED Cable" go to this site and read it all, some excellent info on shift adjustments for the Cobra. Stuarts Cobra Site
WM
I just had the exact same problem on my '91. It was resolved by replacing an electronic switch on the engine (near where the cable attachs to the carb) that cuts out the engine momentarily when you shift. When it is working inermittently or not at all, shifting is extremely hard.
todd5881
Hey david, you may also have the rpms a little high! i have 88 omc cobra small block chevy, and my rpms were at about 900 at idle, and i had the same problems. i backed the idle down to about 600 and everything was good! good luck
