4.3sunbird
- Joined
- Sep 8, 2005
- 73
I ran the model # on my outdrive which I know is a 3.0 unit that was put on my 4.3 boat<br /><br />the unit is a 88 model 3.0 with 13 spline shaft and small lower gearcase<br /><br />from what I've looked at the 4.3 should have the bigger gearcase with more splines <br /><br />well the guy I got it from had the shift cable unhooked from the shifter for manual shifting seperate from the shifter .. well I hooked the cable back to the shifter and it is backwards <br /><br />in better terms forward is reverse and reverse is forward <br /><br />would the earlier unit be opposite of what my 92 boat would be ?<br /><br />I've looked at the shifter and there is no bracket toward the front to loop the cable and hook up from the other way <br /><br />now that I know its backwards I can deal with it till I find a better outdrive to put on it but want to make sure its the drive thats different or maybe the wrong shifter in the boat or something
<br /><br />first time I dropped in the water with it hooked up I about went back up the ramp without the trailer
