Drive is a '93 OMC Cobra mated to a Ford 302 (5.0) HO.
NOTE: I HAVE THE DRIVE WIRED LIKE A MERCRUISER BECAUSE MY ESA MODULE DOESN'T SEEM TO BE WORKING.
My boat shifts fine into forward and comes out of gear into neutral fine, but about 75% of the time when going INTO reverse, it will stall immediately. Since I have it wired like a Merc, it dies instantly, and unhooking the interrupter switch solves the problem, I know that the problem is that the interrupter switch is being held too long while the drive is shifted into reverse (and it shouldn't even be activated at all going INTO gear).
I installed a brand new lower shift cable about 6 weeks ago, measured very carefully, and everything seems to be adjusted correctly (ie. the control box hits reverse and forward evenly, neutral is directly centered, full throttle puts the lever straight forward, etc.).
What can I check/adjust/replace to stop the interrupter switch from being activated while shifting into gear?
I'm beginning to understand the system more and more, but if you could use laymans terms I'd greatly appreciate it.
Any input is appreciated,
Thanks.
Thanks.
