omc cobra switch
sledfreak700
i have a 1992 4 winns horizon with a 302,with a omc cobra.the top gears are blown,and i found 1 from a v-6.will it bolt right up?thanks for any help
Dakota47
Re: omc cobra switch
Yep. may not be the correct ratio but it will bolt up if its a cobra.
sledfreak700
thanks for the help,but do you know if the upper gears are the same and the bottom one's are different ratio?
metro3pilot
It will bolt up
the 4.3 is 21:19
and the 302 V8 has 21:18 gear ratio
