Re: OMC Cobra SX
rod...thanks for the info!<br /><br />I know that taking it out on the lake would be the best situation, but if thats not possible, then I can bring my muffs and skip the tub.<br /><br />In looking over your comments, (forgive my naivity as I'm thinking outboard-2 strokes), when you're talking about the drive oil, are you talking about the lower unit oil? On my old outboard I have a drain plug at the bottom of the skeg...on the I/O, is it the same? I know with the outboard l/us, if the seals are bad the water gets in and the oil turns milky and discolored...same situation with I/Os?<br /><br />You mentioned pulling the drive off (check the coupler, gimbal bearing, bellows)... is that something I can do right there in their driveway, or is this a suggestion for after its bought?<br /><br />The circulating pump weep hole...where and what is that?<br /><br />The seawater pump... same question...isn't that the water pump (with the impeller inside) and something that can only be checked if the drive/lu is pulled? Or are suggesting it for maintenance after its bought? <br /><br />When using muffs...the water will flow through with pressure anyways, regardless of whether the impeller/water pump is working... correct? I know with the tub the pee hole will have water coming out as proof of the water pump working correctly...but with muffs, thats not possible..or do I just assume that if water is coming out the pee hole that everything is fine?<br /><br />With using muffs on an outboard its not recommended to rev the rpms too high... is it the same thought on I/O's?
