Re: OMC Cobra tilt trim hose routing
Lines connect the valve body to the transom manifold which directs fluid to both cylinders. You probably know this much.
I'm looking the the manual and it has a schematic which make it a little difficult.
In trying to decipher the drawing.... the lines feeding the back of the cylinders go through the manifold on the starboard side and appear to go to the back of the pump. The lines feeding the front of the cylinders go through the manifold portside and to the front of the pump near (under) the pressure release valve.
Does this help?
