GopherPride23
- Joined
- Feb 1, 2010
- 16
I posted a thread about this before, but I took a picture now so you guys could see what I am talking about. When running on muffs, and I am presuming when the boat is in the water (though I do not know for sure) water is leaking very profusely out of the outdrive right by the anode. I checked to make sure it wasn't coming from the bellows, its not. It's definetly coming from the outdrive.
1. Is this a normal/okay place for water to be coming out?
2. When I got the boat 6 months ago there was not water in the outdrive oil, it was clean. I changed it anyway. Now after putting probably 20 hours or so on the boat, the oil in the outdrive is milky. From what I have looked at on this board it is most likely the the prop seal(s). But, could the above problem be playing into the milky oil? Could a faulty gasket/oring on the dipstick be letting water into the oil?
Thanks in advance...
