HighLineCBR
- Joined
- Jul 6, 2008
- 104
Hi all,
So i finally pulled my 1989 OMC Cobra outdrive which is mated to a 5.7L Chevy 350.
My original problem started with not being able to shift into reverse. disconnected the lower shift cable at the top and tried to switch by hand to eliminate some of my suspicions. Shifted fine into Forward and Neutral. Could not push it into Reverse manually. After i took off the cable I eliminated that this could be a shifter problem.
SO when i pulled the drive... here's what i found. Enjoy the pics!
Apparent hole in the Drive shaft bellow, with visible water intrusion. (I'm surprised it never leaked into the bilge). Rusted and SHOT gimbal bearing as well as shot u-joints.
GIMBAL
U-JOINTS
Also found that the right under the exhaust bellow i have a hair line crack in the housing. Could this be a problem? Technically water comes out in that chamber anyway with exhaust.
CRACK
When I look into the exhaust chamber i see a weird rubber flap like piece just laying there. Its not attached to anything and I cant get it out because its bigger then the hole it needs to pass through in order to come out. I'm thinking it was meant as a valve not to allow water to come back in but only to let water out with exhaust. But why would it not be attached in any way? Should it be?
Rubber "flap"
Take a look at the gimbal bearing pic below. In order to take this out do i need to remove the lip marked with the red arrow frist? It looks like it could be a screw in looking at the cut away top and bottom sections. But not sure. Or do i just pull the bearing out at this point as is? Please advise on this.
Gimbal Bearing
LASTLY
Instead of rebuilding this outdrive, which i will have to do again... (just rebuilt last year). I'm contemplating putting on a brand new ALPHA ONE, well the SE116 from www.Sterndrive.cc with their new OMC adapter kit. is it worth it? Brand new and with 3 year warranty. WIll it work well with the OMC thou?
lots of info here in one post but hope you can find your way around and help me out by answering my questions above.
thanks!
GIMBAL
U-JOINTS
CRACK
Rubber "flap"
Gimbal Bearing
LASTLY
thanks!
