Okay, I got the pinion gear retaining nut off! I thought that was a miracle without the SST. I thought the whole shaft would then slide out with bearings, etc., because I need to replace the oil seals. I've posted some pics of the oil seal side, and you can see that the seals are popping out. Originally I thought water had intruded the upper and cracked the case, as I found a pool of oil and water under the boat this spring. After tearing the outdrive down I saw the oil-seal problem and hoped it was going to be any easy fix (as in I could do it myself). It took alot of effort just to get the pinon nut off, and now what? The manual talks of arbor press and such. Can I please get some adivce on how to take this thing apart so I can just replace the oil seals? Thanks!
