Swivelhart
- Joined
- Nov 5, 2008
- 185
I have a 1966 Electric Shift Stringer mounted to 155hp Buick V6. This is on my 1967 Larson Volero. The water pump shaft stripped in the upper housing and when I pulled it out I saw a most unusual seal assembly. On the shaft is a circlip groove for a circlip then a spring and at the end of the spring a collar that slides over the shaft splines. I am assuming that the pressure of the spring is supposed to keep water from entering the shaft splined area where it mates to the pinion shaft. I have no idea what this thing is called (the collar seal) and I desperately need another one as the spline grooves have much wear. Any help would be greatly appreciated.
(What is this thing called?)
