Re: omc engine coupler
Ayuh,....
While I don't Do OMCs,.....
I looked in the Serria catalog at the Merc listings,...
There are couplers listed for both crankshaft bolt patterns,....
18-2171 is the older bolt pattern of, I believe 3,1/4"...
18-2172 is the 3" pattern for the late model Chevy crankshaft pattern....
I guess the Question is,....
Are the OMC crankshaft mounted couplers the same Length as the Merc crankshaft mounted couplers,..??..??..??
Now,.... I've Seen 1 Once,.....
And,...
I know the bolt pattern is the Same,...
And,..
The Spline count,+ diameter are the Same,....
But,...
I never measured to see if the crankshaft to driveshaft lengths are the Same......
Did the little 3.0l go to the smaller bolt pattern at the same time as the V6s,+ V8s,..??
Where I've been looking, they go by serial #s,.. Not the Year....
