Re: OMC Engine Swap
I have an answer for you; I'm also going to e-mail this info to you.<br />2.5L Water-Intercooled Turbo (WLT) like the one in the Everest, is manufactured by Detroit Diesel's subsidiary "Motori" <br />in Cento, Italy. 4 cylinder, in-line 16 valve, electronic fuel injection. Turbocharged, intercooled. 145 HP at 2000RPM<br />and peak torque of 251 ft. lbs., at 1800 RPM. Cast iron block with one-piece aluminum head. 21" long, 25" wide and 27" <br />high. 485 LBS. Purely automotive and the low RPM's wouldn't give much speed but it sounds like a durable engine.<br /><br />3.0L GM engine, for marine use; in-line 4 cylinder 145 HP, 181CID 4300-4600 RPM, direct replacement for 2.5L gas engine and 3.0L gas. approximately 500 LBS. Always available
