Re: OMC Engine Tuner REVISITED
HI, When you spray the product into the motor, it will start smoking. The smoke will clear out while the engine is running, after you stop spraying the product into it. Let it run for a few minutes to clear the smoke. I forgot to mention, after you start spraying the product into it, you should shut the motor off for about an hour, then re-start the motor and clear the engine tuner out of it. You should NOT let the product sit in the motor for long periods of time.
