After rebuilding my carb because of what I thought was an idle circuit problem. And also after going through other fixes and general tuning of my engine I am convinced my problems are not in the Carb. I am also convinced that my problems are not fuel related.
I could go through all that but you could read my other posts if you would like to relive it.
Here it was it did last time.
Consistently the last several trips I can launch and run at idle or at speed for a good 30-60 minutes. When the boat is slowed down to idle it dies. It can be restarted and will idle in neutral but when put in gear it dies. I have tried adjusting the 2 idle screws but the engine always seems to favor the approximate starting point. 3 turns out. When it is first started it runs fine. Very smooth. Timing is set at 8 degrees and dwell is nailed on 30 degrees. I was told by a reputable mechanic that 8 degrees is better than 10 degrees because of our ethanol gas. I don't know how or why that is, but I took his advice anyway. At those settings the boat ran very smooth and steady at 4000 rpm and about 32 mph. Temps were steady as well.
When we slowed down and the engine died I let it sit for a good 15 minutes and then tried to restart it. Get's going rather easily in nuetral and then when the shifter is moved forward it dies. It is very consistent. Dies without a cough or sputter, just dead.
I tried to adjust the idle a little higher just to get it going and back to the dock.
Finally I was able to get it putting along in reverse and we managed back to the dock and trailered the boat.
After reading the factory procedure on the ESA and overstroke I will be going through that test and adjustment today.
I believe this may be my only problem.
My main question is; Has this happened to others and do any of you know if it's adjustments or a bad ESA module? Any other advice you'd like to give is also appreciated.
Thanks,
floattest
Thanks,
floattest
