I have a 125 hp Evinrude. Here is what I have found so far...This is the electric push button shift. It never goes out of gear, yet it slips when you put direct power in forward.If I ease the throttle up it will plain out. I connected a jumper wire to the solinoids to test if they were the problem, and they check out fine. 5.7ohms on the solinoids and 12 volts in neutral/reverse no volts in forward. So these have been eliminated. The shift button is working good based on my tests. I switched props to check if it was a spun hub problem...its not that. So I have come to the conclusion it must be within the gear portion somewhere. What should my next steps be to determin the problem. Again, its almost as though it is going into neutral...or not meshing in the gearbox somehow??? Any clues to help me from here would be much appreciated.
